Problem with static variable in the functions.
Hi all.
The source C file is...
void a(void)
static unsigned char var1;
switch(var1){
and the error message is
"error A45 : Undefined Symbol (PASS-2)
I know it is compiled well with C51 and
got a.src file using SRC directive.
but I cant get the a.obj file for assembling it.
I thought it may be the same problem as
'Andrew Neil's Question' in this Disccussion Forum'
How can i do for fixing it.
Thanks. :)
  • You'll have to confirm this in the manual, but I don't think that the A51 Assembler is case-sensitive; therefore you're probably asking for trouble using a name like 'a' for your function - that could well get confused with 'A' for the Accumulator?!
    If that's not the answer, you need to post the Assembler source - as this is an Assembler error!
    "I thought it may be the same problem as 'Andrew Neil's Question' in this Disccussion Forum'"
    Pardon?????????????
  • Another thought:
    Why do you specifically think that it's the static local variable that's causing the problem?
