Hello all, I wrote the following functions for reading and writing to the internal EEPROM but for some reason it not working. Can some tell me what's wrong in this code? void intEepromWr(void *pBuff,uint iEepromAddr,uint iBuffLen){ volatile uchar xdata *pIntEeprom = (uchar xdata *)iEepromAddr; EECON = 0xFC; //Reset value EETIM = 0x37; //5*11.0592MHz in normal mode for (pSram=pBuff ; iBuffLen>0 ; iBuffLen--,pSram++,pIntEeprom++) { while(EECON & 0x01);// Wait while eeprom busy EECON = 0x02;// EEE=1 EEPROM mapped *pIntEeprom = *pSram; // Write data to eeprom EECON = 0x50; EECON = 0xA0; } } void intEepromRd(void *pBuff,uint iEepromAddr,uint iBuffLen){ volatile uchar xdata *pIntEeprom = (uchar xdata *)iEepromAddr; EECON = 0xFC; //Reset value EETIM = 0x37; //5*11.0592MHz in normal mode EECON = 0x02; // EEE=1 EEPROM mapped for (pSram=pBuff ; iBuffLen>0 ; iBuffLen--,pSram++,pIntEeprom++) { while(EECON & 0x01); // Wait while eeprom busy *pSram = *pIntEeprom; // Read data from EEPROM } EECON &= 0xFC; } Thanks a lot, Roberto
Take a look at this link: http://www.keil.com/support/docs/2304.htm
