Now I compile my program and counter one error.which is: ERROR L107:ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT:_DATA_GROUP_ LENGTH: 006EH I can compile it if I select the memory model of compact or large,but the small model will counter above linker error.and in my project has the datap.c file and hasn't _DATA_GROUP_ SEGMENT,could you tell me the possible reason about it and how can I resolve it?thanks
Turn optimization on to full, e.g. OT(9, SIZE). Next, declare storage for every variable. Every one. E.g. for arrays, put them in xdata or idata if you don't have any xdata. For small varaibles that have to be fast, put them in data. For variables that get accessed rarely put them in xdata. Any const variables should be declared in code, otherwise they go in the default memory space (DATA for the small model) as do all variables not given an explicit storage type. See my UART driver for an example of using code, data, idata, and xdata storage qualifiers. It's free at http://www.embeddedfw.com (link at bottom of page) and it was built with the small memory model.
Take a look at the following knowledgebase article. http://www.keil.com/support/docs/1241.htm Jon
