Can I use keil 5.11a for stm32 with my own drivers? or I have to use keil software packs for stm32?
what about startup assembly file and other cortex m related file?
I'm totally baffled by this.
How can anyone talk about using their own drivers if they don't already have an understanding of how the tools operate?
I am programming with keil 4.xx, I am not understand keil 5.xx RTE drivers!
There is no isolation(independent coding, define API for driver layer) between middleware and drivers.
Drivers are optimized for some applications.
Answer to my question if can,unless let others help me.
You are in serious trouble!
Drivers for embedded processors normally don't have any unifying API to translate them into some generic "PC-class" devices. Any extra glue adds extra code size and adds extra delays - and also requires the specific strengths of a specific chip to be ignored to have it emulate basic functionality.
With older generation embedded processors, people often didn't even try to write any drivers - they wrote the driver code inlined in their application code just to cut some instruction cycles here and there.
