Hi I just upgrade may MDK 5.11 to latest packages but I face many error when select Ethernet interface (Phy DP83848C) using MDK-Pro it ask me for Ethernet API (KSZ8851SNL) and if I select that it show me error about SPI driver Keil::CMSIS Driver:Ethernet:KSZ8841SNL require 2.01:CMSIS Driver:SPI and no way to fix it I try to change packages use package select but no hope even STM32F107 example are not working is anyone have any recommendation or suggestion that may fix this By many thanks AL
Hello Al,
please check out the following application note that describes how to use MDK v5.11a with STM32 devices: http://www.keil.com/appnotes/docs/apnt_266.asp
Kind regards,
Christopher
Sorry man and tnx for replay this is wrong thread it is accidently posted two times due my browser refreshed but main thread is hear http://www.keil.com/forum/58387/#msg189264 I check that but that don’t fit my problem other peripherals works fine with that application note but networks not
