GPIO Interrupts trigger problem
I am using LPC1788 controller (FBD208pin package).
I use some GPIO lines of Port 0 and 2 as external interrupts. There are Opto couplers, proxy sensors, etc sensors (that generate single pulse) are connected to these interrupt pins.
Port 0.0, 0.1, 0.3 & 0.4 are configured to generate interrupts on rising and falling edges.
the problem is that, when port 0.0 interrupt is activated, port0.3 & port0.4 interrupts also get activated. This results to false triggering and execution of false ISR.
dont know how to tackle such a problem.
In no way are the port pins connected to each other (i have verified the hardware). neither are they near to each other (so i dont doubt on stray capacitance).
Is there some problem in software, or hardware. I am unable to conclude and dont know where to and what to start debugging.
0
