STM32F103 USB HID using Endpoints (no answer from EP1)
Hi Guys,
I sit for days on my USB transfer. I work with a STM32F103C8 microcontroller.
I want to build a transmission with 2 endpoints to transfer my Data from the (GUI) Host.
My problem are the endpoints. I can not get data from the endpoint.
It is the KEIL USB Library...
Here some code snippets:
//********************************Defines****************************************
#define USB_POWER           0
#define USB_IF_NUM          1
#define USB_EP_NUM          2
#define USB_MAX_PACKET0     8
#define USB_DBL_BUF_EP      0x0040
#define USB_POWER_EVENT     0
#define USB_RESET_EVENT     1
#define USB_SUSPEND_EVENT   0
#define USB_RESUME_EVENT    0
#define USB_WAKEUP_EVENT    0
#define USB_SOF_EVENT       0
#define USB_ERROR_EVENT     0
#define USB_EP_EVENT        0x0003
#define USB_CONFIGURE_EVENT 0
#define USB_INTERFACE_EVENT 1
#define USB_FEATURE_EVENT   0
#define USB_CLASS           1
#define USB_HID             1
#define USB_HID_IF_NUM      0
#define USB_MSC             0
#define USB_MSC_IF_NUM      0
#define USB_AUDIO           0
#define USB_ADC_CIF_NUM     0
#define USB_ADC_SIF1_NUM    1
#define USB_ADC_SIF2_NUM    2
#define USB_CDC             0
#define USB_CDC_CIF_NUM     0
#define USB_CDC_DIF_NUM     1
#define USB_CDC_BUFSIZE     64
//***************************My Buffer Variables************************************
uint8_t InReport[64];
uint8_t  OutReport[64];
I get no call interrupt at this point
void USB_EndPoint1 (U32 event) {
 GPIOB->BSRR |=(1<<1); //Set PB1 only for debuging with Osziloscope
  switch (event) {
  case USB_EVT_IN:
  GetInReport();
  USB_WriteEP(0x81, InReport, sizeof(InReport));
  break;
  case USB_EVT_OUT:
  USB_ReadEP(0x01, OutReport);
  SetOutReport();
  break;
GPIOB->BSRR |=(1<<17); //Clear PB1 only for debuging with Osziloscope
const U8 HID_ReportDescriptor[] = {
  HID_UsagePageVendor( 0x00                     ),
  HID_Usage          ( 0x01                     ),
  HID_Collection     ( HID_Application          ),
    HID_LogicalMin   ( 0                        ),  //value range: 0 - 0xFF
    HID_LogicalMaxS  ( 0xFF                     ),
    HID_ReportSize   ( 8                        ),  // 8 bits
    HID_ReportCount  ( 0x40   ),
    HID_Usage        ( 0x01                     ),
    HID_Input        ( HID_Data | HID_Variable | HID_Absolute ),
    HID_Usage        ( 0x01                     ),
    HID_Output       ( HID_Data | HID_Variable | HID_Absolute ),
    HID_Usage        ( 0x01                     ),
    HID_Feature      ( HID_Data | HID_Variable | HID_Absolute ),
  HID_EndCollection,
/* USB Standard Device Descriptor */
const U8 USB_DeviceDescriptor[] = {
  USB_DEVICE_DESC_SIZE,              /* bLength */
  USB_DEVICE_DESCRIPTOR_TYPE,        /* bDescriptorType */
  WBVAL(0x0200), /* 2.00 */          /* bcdUSB */
  0x00,                              /* bDeviceClass */
  0x00,                              /* bDeviceSubClass */
  0x00,                              /* bDeviceProtocol */
  USB_MAX_PACKET0,                   /* bMaxPacketSize0 */
  WBVAL(0xC251),                     /* idVendor */
  WBVAL(0x1C01),                     /* idProduct */
  WBVAL(0x0100), /* 1.00 */          /* bcdDevice */
  0x01,                              /* iManufacturer */
  0x02,                              /* iProduct */
  0x03,                              /* iSerialNumber */
  0x01                               /* bNumConfigurations: one possible configuration*/
const U8 USB_ConfigDescriptor[] = {
//Configuration 1
  USB_CONFIGUARTION_DESC_SIZE,       /* bLength */
  USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */
  WBVAL(USB_CONFIGUARTION_DESC_SIZE + HID_DESC_SIZE + USB_INTERFACE_DESC_SIZE + USB_ENDPOINT_DESC_SIZE + USB_ENDPOINT_DESC_SIZE),   // wTotalLength
  0x01,                              /* bNumInterfaces */
  0x01,                              /* bConfigurationValue: 0x01 is used to select this configuration */
  0x00,                              /* iConfiguration: no string to describe this configuration */
  USB_CONFIG_BUS_POWERED,                       /* bmAttributes */
  USB_CONFIG_POWER_MA(100),          /* bMaxPower, device power consumption is 100 mA */
// Interface 0, Alternate Setting 0, HID Class
  USB_INTERFACE_DESC_SIZE,           /* bLength */
  USB_INTERFACE_DESCRIPTOR_TYPE,     /* bDescriptorType */
  0x00,                              /* bInterfaceNumber */
  0x00,                              /* bAlternateSetting */
  0x02,                              /* bNumEndpoints */
  USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */
  0,                            /* bInterfaceSubClass */
  0,                            /* bInterfaceProtocol */
  0,                           /*iInterface*/
//HID Class Descriptor
  HID_DESC_SIZE,                     /* bLength */
  HID_HID_DESCRIPTOR_TYPE,           /* bDescriptorType */
  WBVAL(0x0100), /* 1.00 */          /* bcdHID */
  0x00,                              /* bCountryCode */
  0x01,                              /* bNumDescriptors */
  HID_REPORT_DESCRIPTOR_TYPE,        /* bDescriptorType */
  WBVAL(HID_REPORT_DESC_SIZE),       /* wDescriptorLength */
// Endpoint, HID Interrupt In
  USB_ENDPOINT_DESC_SIZE,            /* bLength */
  USB_ENDPOINT_DESCRIPTOR_TYPE,      /* bDescriptorType */
  USB_ENDPOINT_IN(1),                /* bEndpointAddress */
  USB_ENDPOINT_TYPE_INTERRUPT ,       /* bmAttributes */
  0x40,0x00,                        /* wMaxPacketSize */
  0x01,          /* 32ms */          /* bInterval */    //0x20
//Endpoint, HID Interrupt out
  USB_ENDPOINT_OUT(1),                /* bEndpointAddress */
  0x01,          /* 32ms */          /* bInterval *///0x20
/* Terminator */
  0                                  /* bLength */
The USB Sniffer shows the correct port setting. But why the endpoint interrupt is not executed?
I see data packets (every 1ms) at the USB data pin on the oscilloscope.
But unfortunately, the device receives nothing...
Who can help me in the initialization?
I have read many Theards, but it does not work ..
Best Regards
Peter
  • next
    BOOL HID_GetReport (void) {
      /* ReportID = SetupPacket.wValue.WB.L; */
      switch (SetupPacket.wValue.WB.H) {
        case HID_REPORT_INPUT:
          //GetInReport();
          //EP0Buf[0] = InReport;      //I Removed EP0 transmisson
          break;
        case HID_REPORT_OUTPUT:
          return (__FALSE);        /* Not Supported */
        case HID_REPORT_FEATURE:
          /* EP0Buf[] = ...; */
          /* break; */
      return (__TRUE);
    BOOL HID_SetReport (void) {
          //OutReport = EP0Buf[0];       //I Removed EP0 transmisson
          //SetOutReport();
          break;
      return (__TRUE);
    //*********************************USBSniffer Report***************************************
    port 2 : USB-HID (Human Interface Device)
    Parameter       Value
    Hardware ID     USB\Vid_c251&Pid_1c01&Rev_0100
    Setup Class     HIDClass
    Class GUID      {745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
    PDO Name        \Device\USBPDO-8
    Service Name    HidUsb
    Parameter       Value
    Connection Information
    ConnectionIndex         0x2
    CurrentConfigurationValue       0x1
    Speed   0x1 (UsbFullSpeed)
    DeviceIsHub     FALSE
    DeviceAddress   0x1
    NumberOfOpenPipes       0x2
    ConnectionStatus        DeviceConnected
    Pipe #0
    Endpoint Descriptor
    bLength         0x7
    bEndpointAddress        0x81 [IN]
    bmAttributes    0x3 (USB_ENDPOINT_TYPE_INTERRUPT)
    wMaxPacketSize  0x40
    bInterval       0x1
    Pipe #1
    Endpoint Descriptor
    bLength         0x7
    bEndpointAddress        0x1 [OUT]
    wMaxPacketSize  0x40
    bInterval       0x1
    Device Descriptor
    bLength         0x12
    bcdUSB  0x0200 (USB 2.0)
    bDeviceClass    0x0
    bDeviceSubClass         0x0
    bDeviceProtocol         0x0
    bMaxPacketSize0         0x8
    idVendor        0xC251 (Keil Software, Inc.)
    idProduct       0x1C01
    bcdDevice       0x100
    iManufacturer   0x1 (0x409: Keil Software)
    iProduct        0x2 (0x409: Keil MCBSTM32 HID)
    iSerialNumber   0x3 (0x409: 0001A0000000)
    bNumConfigurations      0x1
    Parameter       Value
    Configuration Descriptor
    bLength         0x9
    bDescriptorType         USB_CONFIGURATION_DESCRIPTOR_TYPE
    wTotalLength    0x29
    bNumInterfaces  0x1
    iConfiguration  0x0
    bmAttributes    0x80 ( Bus_Powered )
    MaxPower        0x32
    Interface Descriptor
    bLength         0x9
    bInterfaceNumber        0x0
    bAlternateSetting       0x0
    bNumEndpoints   0x2
    bInterfaceClass         0x3 (Human Interface Device)
    bInterfaceSubClass      0x0 (No Subclass)
    bInterfaceProtocol      0x0 (None)
    iInterface      0x0
    Endpoint Descriptor
    bLength         0x7
    wMaxPacketSize  0x40
    bInterval       0x1
    Endpoint Descriptor
    bLength         0x7
    wMaxPacketSize  0x40
    bInterval       0x1
  • Hey Tsuneo,
    cool that you responded so quickly =) I've read many reports from you.
    All are really excellent.
    Yes, I want to build a bidirectional connection to the host.(An example in C++ .Net).
    It should act like a UART connection.
    In and Out connection with interrupt mode at 64 byte per frame.
    I have changed the example (C:\Keil\ARM\Boards\Keil\MCBSTM32\USBHID) and added the endpoint 1.
    I guess it works so far. Further up the thread is a report from the USB connection device.
    I do not know if everything is correct. But you can see the Report from USB Sniffer.
    But I know now that I need only one endpoint, because this IN and Out support.
    I'll change it now in my firmware.
    Thats the .net GUI Interface:
    unsigned char OutputPacketBuffer[65];
    unsigned char InputPacketBuffer[65];
    private: System::Void get_set_data_from_device(System::Object^ sender, System::EventArgs^  e){
      DWORD BytesWritten = 0;
      DWORD BytesRead = 0;
    InputPacketBuffer[0] = 0;
    OutputPacketBuffer[0] = 0;
    OutputPacketBuffer[1] = 0x00;  //Some Values in my send buffer
    OutputPacketBuffer[2] = 0x01;  //Some Values in my send buffer
    OutputPacketBuffer[3] = 0x01;  //Some Values in my send buffer
    WriteFile(WriteHandle, &OutputPacketBuffer, 64, &BytesWritten, 0); //Sending process
    ReadFile(ReadHandle, &InputPacketBuffer, 64, &BytesRead, 0);       //Receiving process
    InputPacketBuffer[1]; //Some data from my Device at the endpoint IN
    InputPacketBuffer[2]; //Some data from my Device at the endpoint IN
    InputPacketBuffer[3]; //Some data from my Device at the endpoint IN
    The problem is, that i never received or sends some data to or from my Device (STM32F103C8)....
    Just *** =(
    Beste Regards
    Peter
  • On the host application,
    Count in the report ID byte for the nNumberOfBytesToWrite of WriteFile() and nNumberOfBytesToRead of ReadFile(), even if no report ID is used on the report descriptor. To send 64 bytes report of no report ID, 65 bytes (report ID: 0, and following 64 bytes report body) are exchanged.
    WriteFile(WriteHandle, &OutputPacketBuffer, 65, &BytesWritten, 0); //Sending process
    ReadFile(ReadHandle, &InputPacketBuffer, 65, &BytesRead, 0);       //Receiving process
    Tsuneo
  • Ah, on the device side,
    device receives / sends just 64 bytes report, without report ID.
    PC HID driver strips / adds the report ID: 0.
    Tsuneo
