There is an example program \Keil\ARM\Examples\Blinky, which runs nicely with the Simulator mode of the debugger.
This uses the chip settings STM32F103RB.
But if I try to change this to STM32F407VG (or other STM32F4 chips I tried), the simulator does not run any more. It then somehow switches to a very strange single step mode - It does not come at the start of the main function (although I set the checkbox "Run to main()" in the Target page "Debug"), and if I try to run the program, it somehow runs only one step further - I cannot convince the simulator to run it correctly.
"STM32F103RB ... I try to change this to STM32F407VG"
I'm not sure that simply changing the processor name ever (quite) "just works" - even less likely with a step-change in architecture like that!
What happens if you use a provided STM32F4 sample straight "out of the box"?
What happens if you create a new STM32F4 project from scratch?
Doesn't work unfortunately.
(I tried the C:\Keil\ARM\Boards\Keil\MCBSTM32F400\Blinky and the C:\Keil\ARM\Boards\ST\STM32F4-Discovery\Blinky - neither of them works in Simulation mode).
Thank you, so it is not my stupidity, I am relieved.
As the STM32 family contains very many derivates: Is there some list available, which STM32 devices are supported by the simulator? (are there any STM32F4 devices supported?)
I suppose that as an STM32F4-Discovery costs $15-20 one can use real hardware.
