As i am currently working in USB MASS STORAGE for BIOCRYPT Application . Working In AVR32 Studio PLATFORM (ATMEL Controller).In my project, i want to create 4 LUN(PARTITION) for our Application Process (2 for CD-ROM & 2 for REMOVABLE),Now i created 3 LUN(1 CD-ROM(BOOTABLE) & 2 REMOVABLE) & it been ENABLE & Working properly .But 4th (cd-rom( NON BOOTABLE )) is not been readed .I don't know what changes to do in code i do all changes but i didn't get output. Can u plz suggest your ideas to solve this problem .
thank in advance
regards, janaki.
So what does that have to do with Keil??
Hmmm. Tel me if this problem occur in keil . what ur idea will be?
The trick I think is to hire competent coders, and post to forums related to the question? No?
I can't solve that, let me know when you figure it out.
No, this particular problem would not occur - because no Keil tools support AVR!
ok andrew thank for ur reply. Leave this keil , AVR etc. General suggest ur idea to solve this issue.
The general solution is probably to ask the people who are using the Atmel code. It isn't unlikely that they can be reached on some Atmel forum.
Because this is not a general question. Your problem is related to specific code you are using. Users of other code aren't likely to see your issues. And aren't likely to need similar solutions that you need.
