Hi, does anyone have code for using the ethernet interface on the MCBSTM32F400 board?
I have tried the lwIP sample code downloaded from ST, but it is written for another hardware. It uses a PHY transceiver from TI. The Keil board has a ST802rt1A PHY transceiver.
/Peter
I am very interested on that question... have you solved it? Can you or anyone help with that?
Thanks, Rafael
Hi, I had to modify some of the files in order to get the communication with the PHY device to work. I don't remember the exact changes for the moment. I have to go back and check in the code. I'll be back.
Thank you so much! Did you "played" with the audio of this board? I am having a lot of problems to let it works and nobody knows too much about this board...
Thank you so much Peter! I will work with your ethernet files when the audio works... Why have I bought that evaluation board... :S :S :S
