Dear,
I have installed the version 4.70a of uVision and my ULINK 2 firmware has been updated. On board with Cortex M3 I have no problem (LPC1768 or LPC1857) but for board with ARM 7 (LPC2468 or LPC2136), the micro is not detected and it says "No ULINK device found". I have tried with my own project and with MCB2400 Blinkly example with the same result.
Yannick
Might be worth you checking this:
http://www.keil.com/support/man/docs/ulink2/ulink2_boot_mode.htm
The page is mentioned in the release notes.
DJR
Thank you very much for your help. It seems to work but as I have to work on the two micro architecture very often, it's quite annoying.
Create a .bat file (or a pair of .bat files) to configure the uLink appropriately?
Add the command as a pre-build step in the uVision project?
Yes it's the faster way to do it. Thank you.
Fantastic. Firmware update per chip family. How wonderful.
"Fantastic. Firmware update per chip family. How wonderful."
Not as bad as the Microchip PIC tools I'm having to use at the moment. It sometimes feels like their ICD 2 needs reprogramming for each device. It's automatic but ... yeuch.
The bad thing is that we don't know how the ULINK2 handles these commands. Performing writes into program flash (even if not changing setting?) or is the information stored in an EEPROM with a very high endurance?
"Performing writes into program flash (even if not changing setting?) or is the information stored in an EEPROM with a very high endurance?"
300 euro per unit !
