I use the Keil MDK for study the CMSIS-RTOS RTX Version 4.74, it is the up to date version. My Development Board is Cortex-M4 STM32F407VG. I use the "Manage the run-time environment" build the project. In the RTX_Conf_CM.C, #define OS_TIMERS 1. But when I run the below program , osTimerCreate returns 0 to id1 and id2. why? Thanks.
#include "cmsis_os.h" int count = 0; void Timer1_Callback (void const *arg){count++;} // prototypes for timer callback function void Timer2_Callback (void const *arg){count--;} osTimerDef (Timer1, Timer1_Callback); // define timers osTimerDef (Timer2, Timer2_Callback); uint32_t exec1; // argument for the timer call back function uint32_t exec2; // argument for the timer call back function int main (void) { osTimerId id1; // timer id osTimerId id2; // timer id // Create one-shoot timer exec1 = 1; id1 = osTimerCreate (osTimer(Timer1), osTimerOnce, &exec1); if (id1 != NULL) { // One-shoot timer created } // Create periodic timer exec2 = 2; id2 = osTimerCreate (osTimer(Timer2), osTimerPeriodic, &exec2); if (id2 != NULL) { // Periodic timer created } }
Hello Long Shi, I have the same problem with my project; did you find the solution? Thanks for your answer.
