adaptive headlight control system
am currently doin a project on adaptive automobile head lamps in which i need to use two stepper motors for left and right head lamps respectively. each motor has to turn in respective directions for 15-18 degrees and return back to 0 degrees. the motors should turn when the steering angle changes. can you help in in coding of the same project.
