I'm trying to do something along the lines of
file = "filename" main ( file , "Q4" )
Is there a way of building up a command like that?
Err, what?
what do you mean? can you help?
No! - because we have absolutely no idea what it is that you're asking!
Remember that nobody here knows anything about you, your background, or what you're trying to achieve other than what you clearly and explicitly state in your posts!
www.catb.org/.../smart-questions.html
i thought this was a forum for programmers. obviously wrong. wasting my time and your time. goodbye.
It's a forum for discussing Keil products: http://www.keil.com/forum/
If you are a programmer, you should understand that it's impossible to write a program without an adequate specification.
If you're not a programmer, you need to understand that it's impossible to write a program without an adequate specification.
"wasting my time and your time"
Aparently so.
Enrage timer reached?
I have the feeling you might have some MMO experience...
All work and no play makes Jack a dull boy All work and no play makes Jack a dull boy All work and no play mmakes Jack a dull boy All work and no PLay makes Jack a dull boy All work and no play makes Jack a dull boy
