I'm trying to use the Mode command as outlined on this page: http://www.keil.com/support/man/docs/uv4/uv4_db_srl_io_to_com.htm
And I'm getting an error: > MODE COM2 9600, 0, 8, 1 Mode COM2 command failed.
Ideas?
Do you have any COM2?
No, it's available, shouldn't Keil "create" COM2?
No - "COM2" refers to either a physical COM port, or a virtual COM port previously created.
If that's the entire message that you get (which, unfortunately, I can believe) then it must be a very strong contender for the World's Most Useless Error Message award!
