Hey guys Im new in the topic of 32bit controllers and im currently using the NXP1768 with the keil ide. In the user manual to the they tell me about a configuration wizard that can be used to edit for example the net_config.c
Can anyone please tell me how to open the wizard and configure my files? I wanted to start with the tcp socket example in the user manual. I inclueded all the files to my project from the keil folder in my programmfiles. but nothing works. The console says that ARP_NOTIFY is not defined. I tried to define it in the .c file but it caused more problems. It seems that i have to change the configuration. It would be nice if you could help me out.
Or tell me what i am doing wrong in principle.
Thanks a lot for your attention
For files that uses the configuration wizard, you normally just open up that source file.
Then if you look at bottom of that window, you'll note two tabs. One for text view and one for wizard view. The wizard scans the source file for special comments in the source file and presents a dialog interface where you turn on/off different configuration options.
Me too i have the same problem i ca't make my configuration using the wizard
