Placing a checksum at the end of the used flash
Hello
I am wanting to place a checksum at the end of the flash image. I have a crc.c that only has this array - where I will manually replace xx and yy with the 16bit CRC, once I have made a .bin image. (...wish there was a way for the compiler to do this automatically)
const unsigned char  __attribute__((aligned (16)))ucCRC[16] =
' ',    ' ',    ' ',    'C',    'R',    'C',    'xx',    'yy'
Using the Scatter-Loading Description File I have this
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x08040000 0x000B00000
        {    ; load region size_region
        ER_IROM1 0x08040000 0x000B00000
                {  ; load address = execution address
                *.o (RESET, +First)
                *(InRoot$$Sections)
                .ANY (+RO)
        RW_IRAM2 0x10000000 0x00010000
                {  ; RW data
                kLokIram2.o(+RW +ZI)
                ttydebugout.o(+RW +ZI)
                ttydebugin.o(+RW +ZI)
        RW_IRAM1 0x20000000 0x00020000
                {  ; RW data
                .ANY (+RW +ZI)
Without manually placing each .o section, how do I place the crc.o or ucCRC[16] after the .ANY (+RO) in the ER_IROM1 region?
I tried crc.o (+RO, +Last) - but the linker does not allow that - error: L6235E: More than one section matches selector - cannot all be FIRST/LAST.FIRST/LAST.
Any help would be much appreciated
  • You've got an 11MB Flash?
    Thoughts, shrink IROM1, and create a 16 byte IROM2 sector AFTER IROM1, not inside it.
    const unsigned char *ucCRC = (unsigned char *)0x08B40000;
    Keil tools expect you to create post-link user functionality to sign/package the linker output in a form that uniquely suits your needs/requirements.
  • This forum really needs registration, and editing...
    const unsigned char *ucCRC = (unsigned char *)0x08B3FFF0; // 16-byte prior to end-of-flash
  • Perhaps I am not making myself clear. The flash is located at that address in a STM32F417 memory map. I could readily declare -
    const unsigned char  __attribute__((at(0x08B3FFF0)))ucCRC[16] =
    ' ',    ' ',    ' ',    'C',    'R',    'C',    ' ',    ' '
    and the linker would place it there... That is not what I want - I want to place ucCRC[] at the end of the application code + RO data, about 200K bytes worth.
    Please elaborate on your "This forum really needs registration, and editing..." - I do not understand such a comment - I thought that this was a forum to assist users of Keil products?
  • Um, let's think about that, if I could edit my posts I could correct inaccuracies instead of posting a second one correcting the first.
    For example your STM32F417 does not have 11MB (0xB00000) of FLASH.
  • crc.c
    main.c
    extern const unsigned char ucCRC[16];
    project.sct
    LR_IROM1 0x08040000 0x000B0000  {    ; load region size_region
      ER_IROM1 0x08040000 0x000B0000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      RW_IRAM1 0x20000000 0x00020000  {  ; RW data
       .ANY (+RW +ZI)
    LR_IROM1_END +0 0x10
      ER_IROM1_END +0 0x10
        crc.o (*, +Last)
    out.bin
    00000000 : 20 04 00 20 9D 01 04 08 - A3 04 04 08 9F 04 04 08    .. ............
    00000010 : A1 04 04 08 CF 03 04 08 - E1 06 04 08 00 00 00 00   ................
    00000020 : 00 00 00 00 00 00 00 00 - 00 00 00 00 D9 05 04 08   ................
    00000030 : D1 03 04 08 00 00 00 00 - 29 05 04 08 8D 06 04 08   ........).......
    00000040 : B7 01 04 08 B7 01 04 08 - B7 01 04 08 B7 01 04 08   ................
    00000050 : B7 01 04 08 B7 01 04 08 - B7 01 04 08 B7 01 04 08   ................
    00000710 : 38 BD 00 00 FF F7 5E FE - 00 20 FF F7 1F FF 00 20   8.....^.. .....
    00000720 : FF F7 40 FF FF F7 BE FE - FF F7 5C FD 01 48 00 F0   ..@.......\..H..
    00000730 : 03 F8 FE E7 C0 07 04 08 - 10 B5 04 46 01 E0 FF F7   ...........F....
    00000740 : DF FF 14 F8 01 0B 04 49 - 00 28 F8 D1 BD E8 10 40   .......I.(.....@
    00000750 : 0A 20 FF F7 D5 BF 00 00 - 1C 00 00 20 00 00 06 00   . ......... ....
    00000760 : 01 00 01 00 01 00 00 00 - 00 10 00 20 00 40 00 80   ........... .@..
    00000770 : 08 00 00 00 08 00 00 00 - 08 00 00 00 08 00 00 00   ................
    00000780 : A0 07 04 08 00 00 00 20 - 20 00 00 00 E2 06 04 08   .......  .......
    00000790 : C0 07 04 08 20 00 00 20 - 00 04 00 00 F2 06 04 08   .... .. ........
    000007A0 : 00 00 00 00 00 00 00 00 - 00 00 02 40 00 0C 02 40   ...........@...@
    000007B0 : 00 0C 02 40 00 0C 02 40 - 00 0C 02 40 00 00 00 00   ...@...@...@....
    000007C0 : 20 20 20 20 20 20 20 20 - 20 20 20 43 52 43 78 79              CRCxy
  • That's what I was looking for - thanks Pier - and yes that 0x000B00000 was a bit of a typo. Much appreciated.
