Polish signs in Keil uVision 5.0
Hallo,
I try to use uVision 5 (normally I work with 4.13a). I found that new version of Keil has problem with Polish signs (it works fine in 4.13a). I tried to change encoding, but without success. When I set “Encode in ANSI” I can not put polish letters (using Alt + letter). When encoding is set UTF-8 putting polish signs is possible, but they are written as two bytes signs (what generates problem for example with strings in C).
Is there any solution for this situation? uVision 4.13a is for me fine, but I want to work with STM32F4xx, which dose not exist in an old version.
Grzegorz
electronic engineer
