Flash download failed
Hello guys,
I am currently working on my stm32f3 board and i have some issue regarding the flash.
Until now i was able to download my code the flash. Now, i get a message saying :
Internal Command Error [ OK ]
Error: Flash Download Failed Target DLL has been cancelled [ OK ]
I searched through the forums but didnt had any luck in solving my problem.
I have the following set up:
Debug : St-Link Debugger Port SW
In SW Device, in Debug settings i have "No cortex M SW Device Found" despite having it connected to my laptop.
Is there a chance that my board might be broken?
Regards, and thanks in advance.
  • Your own board, or a Discovery board?
    Does the ST-Link have most current firmware?
    Are you using "ST-Link (Deprecated)" or "ST-Link Debugger"?
    Do the ST-Link utilities work?
    If you strap BOOT0 High can you find/erase the device?
  • Thanks for the fast Resposne.
    Yes, the Utilities did help and i erased the whole flash.
    Im curious, what do you mean by
    "If you strap BOOT0 High can you find/erase the device?"
    what is the BOOT0 and how can i strap it high?
    Regards
  • BOOT0 being high (3V) causes the device to reset into it's System Loader mode, from here you can use USB DFU updates, or serial via the Flash Demonstrator.
    If your user code breaks the device, say you reprogram the GPIO's used for SWD/JTAG, put the device in a low power mode, etc, the ability to NOT run your code permits a method to recover.
    On the STM32F3-DISCOVERY board there is a BOOT0 pin next to a VDD pin, jumper these together, and reset.
