Hi I have some problem with LPC1768 UART1 and FIFO.
1. I use RTX project and in initializing Uart send a string and with receive an response start my tasks. but in receive sequence I RECEIVE ONLY LAST CHARACTER ?????????
for example I send "Hello Jack" and when response "Thank you" ,the only character that recive is "u" !!!!!! but when i tack a few delay between response ,all character receive correctly .
for example i response "T"_delay_"h"_delay_"a".....
2. in Condition
#define BUF_EMPTY(serBuf) (serBuf.rdIdx == serBuf.wrIdx) while (!BUF_EMPTY(out)); // Block until space is available if none
when serBuf.rdIdx=serBuf.wrIdx=0 it work well
but if serBuf.wrIdx and serBuf.rdIdx != 0 it not work and micro goto infinitive condition???
my code is:
/*---------------------------------------------------------------------------- serial port 1 interrupt *---------------------------------------------------------------------------*/ extern "C" void UART1_IRQHandler(void) { volatile unsigned long iir; iir = LPC_UART1->IIR; // Interrupt ID Register if ((iir & 0x4) || (iir & 0xC)) { // RDA or CTI pending while (LPC_UART1->LSR & 0x01) { // Rx FIFO is not empty BUF_WR(in, LPC_UART1->RBR); // Read Rx FIFO to buffer } } else if ((iir & 0x2)) { // TXMIS pending if (BUF_COUNT(out) != 0) { LPC_UART1->THR = BUF_RD(out); // Write to the Tx FIFO txRestart = 0; } else { txRestart = 1; } } lineState = ((LPC_UART1->MSR << 8) | LPC_UART1->LSR) & 0xE01E; // update linestate } /*---------------------------------------------------------------------------- serial port 1 interrupt *---------------------------------------------------------------------------*/ void UART1_IRQHandler(void) { volatile unsigned long iir; iir = LPC_UART1->IIR; if ((iir & 0x4) || (iir & 0xC)) { // RDA or CTI pending while (LPC_UART1->LSR & 0x01) { // Rx FIFO is not empty SER_BUF_WR(ser_in, LPC_UART1->RBR); // Read Rx FIFO to buffer } } if ((iir & 0x2)) { // TXMIS pending if (SER_BUF_COUNT(ser_out) != 0) { LPC_UART1->THR = SER_BUF_RD(ser_out); // Write to the Tx FIFO ser_txRestart = 0; } else { ser_txRestart = 1; } } ser_lineState = ((LPC_UART1->MSR<<8)|LPC_UART1->LSR) & 0xE01E; // update linestate return; } /*---------------------------------------------------------------------------- write data to the serial port *---------------------------------------------------------------------------*/ int HWSerial::Write (const char *buffer, int *length) { int bytesToWrite, bytesWritten; // Write *length bytes bytesToWrite = *length; bytesWritten = bytesToWrite; //while (!BUF_EMPTY(out)); // Block until space is available if none while (bytesToWrite) { BUF_WR(out, *buffer++); // Read Rx FIFO to buffer bytesToWrite--; } if (txRestart) { txRestart = 0; LPC_UART1->THR = BUF_RD(out); // Write to the Tx Register } return (bytesWritten); }
you do not show BUF_WR and SER_BUF_WR 1) why call functions for this 2) the paramters in the calls are different (var/ptr)
I do not click on unknown sites (have been burned severely)
post the routines/macros
