PCB proteus ARES
i am using ISIS proteus ARES 7 for PCB designing, in that i cant generate solder resist's inverted output in pdf format, please kindly anyone help me in generating the PDF file.in that regard jpeg anb bitmap files are generated rightfully but while printing using laser printer the dimension of design comes to fit with hole paper,please any one help in solving this problem. as i am using trail version i cant logon in to labcenter's forum.....
thanks in advance
  • So why ask for help in a Keil forum?
    Do you often go to the meat disk at the local supermarket and ask to buy break pads for your car? The probability of get help really does increase if you start by locating a forum that actually is related to the software you are using...
