Dear sirs and madams
I wish to use timer 1 mode 0 so I need to load a value in TMOD. I am getting confused with the value I need to put in this
So timer 1 uses the high byte bits 4 5 6 7
Bit 4 - M0 Bit 5 -M1 Bit 6 - C/T Bit 7 GATE
I also found that to put it on mode 1 I must set M0 to 1 so what is confusing me is the value I put into TMOD
Is it going to be 0001 0000 which equals 16H - 0x16 ?
Please help me and confirm if this is correct
I messed up my hex conversion
its 0x10
Yes, you did.
"its 0x10"
Yes, it is.
