I want to debug hard fault in LPC1317-64P. I took reference from below site: support.code-red-tech.com/.../DebugHardFault
But code gives error
1. for asm Code:
source\main.c(12): warning: #1207-D: attribute "naked" ignored source\main.c(20): error: #1113: Inline assembler not permitted when generating Thumb code
2. For C Code source\main.c(65): error: #1113: Inline assembler not permitted when generating Thumb code
But code there is for LPCXpresso. How to use it in keil.
#pragma pack(push, 4) typedef struct { uint32_t r0; uint32_t r1; uint32_t r2; uint32_t r3; uint32_t r12; uint32_t lr; uint32_t pc; uint32_t psr; } stacked_regs_t; #pragma pack(pop) //============================================================================= // This is called from the HardFault_HandlerAsm with a pointer the Fault stack as the parameter. // We can then read the values from the stack and place them into local variables for ease of reading. //============================================================================= void hard_fault_debug_print(stacked_regs_t* stack) // prints 8 regs saved on the stack and so on { dprintf("\n\nHard fault:\n"); dprintf("R0 : %#08lx\n", stack->r0); dprintf("R1 : %#08lx\n", stack->r1); dprintf("R2 : %#08lx\n", stack->r2); dprintf("R3 : %#08lx\n", stack->r3); dprintf("R12 : %#08lx\n", stack->r12); dprintf("LR : %#08lx\n", stack->lr); dprintf("PC : %#08lx\n", stack->pc); dprintf("PSR : %#08lx\n", stack->psr); dprintf("BFAR: %#08lx\n", *((volatile uint32_t*)0xE000ED38)); dprintf("CFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED28)); dprintf("HFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED2C)); dprintf("DFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED30)); dprintf("AFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED3C)); } //============================================================================= // Alternative Hard Fault handler to help debug the reason for a fault. // To use, edit the vector table to reference this function in the HardFault vector // This code is suitable for Cortex-M3 and Cortex-M0 cores //============================================================================= __irq __asm void HardFault_Handler(void) // __attribute__((naked)) { EXPORT HardFault_Handler IMPORT hard_fault_debug_print tst lr, #(1<<2) ite eq mrseq r0, msp ; Main Stack was used, put MSP in R0 mrsne r0, psp ; Process Stack was used, put PSP in R0 and after: LDR R0,[R0, #24] ; Get stacked PC from stack b (hard_fault_debug_print) b . }
