can any one provide the link for sample program of sending message to PC with wifi using 8051?
What was wrong with this thread? http://www.keil.com/forum/21955/
You just don't like getting people who answer and gives you links to documentation? Too much own work to actually look at the links? Much better if someone dedicates their private time to specifically hold your hand?
i mean i'm in confusion on whether RN 171 wifi module is interfaced to 8051 or not, and also need sample program for that, i asked about link if it available without spending time to this.
Well, there's your basic problem!
If you are not prepared to spend time on your own project - how can you expect other people to do your work for you?!
You won't get very far with your project if you're not prepared to put the work in!
Still no answer why you felt you couldn't continue with your original thread, but had to start a new. http://www.keil.com/forum/21955/
Creating more threads will not give you more help. But it is a good way to get people to ignore you.
Have you followed up the links you have already been given?
Have you looked at the manual or the application notes? Or do you expect someone else to spend the time and do it for you? Wait - don't answer. I think I already know the answer to that question...
