Q) Which Register should be PUSHed into the stack, when calling a Functin in another asm file using LCALL?
The one you want to keep there.
You push the same registers you would if it were a function in the same file. Or one reached by ACALL.
Thank you Let me try these things out, and will get to you guys back.. Regards, Masood ur Rehman
