Hello! I have some problem with compiling my project in Keil 4.00 When i try to build project i had error: LX51 LINKER/LOCATER V4.41 - SN: COPYRIGHT KEIL ELEKTRONIK GmbH 1995 - 2009 @Main Power Controller.lnp *** ERROR: COMMAND-FILE 'Main' NOT FOUND Maybe somebody help me with this? Thanks!
Problem in project target name! After rename all works fine! Thanks!
To be precise, the problem is the spaces in the name.
Thanks!
also causes problems in folder (directory) names...
