Project File Dependancies
In a Keil uVision IDE project it is possible to enter a list of source files that are to be compiled / assembled into a program. After a build is completed the IDE will display the various include file dependancies in the project file list window. These will display similar to the picture shown here:
i.stack.imgur.com/EXO3P.png
Does anyone know of a way to extract this information out of the Keil tool?
Michael Karas
Note: Cross Posted at www.8052.com/.../188738
  • http://www.keil.com/support/man/docs/uv4/uv4_b_filetypes.htm lists the *.DEP file type as, "Dependency File for a Target build"
    Not sure if it applies to C51 - but could be worth a look...?
  • Andy, Unfortunately this information does not directly help to understand how to extract the dependency information from a project file when clearly that information is already gathered into the IDE.
    Michael Karas
  • In which form do you wish to receive this list? Why can't you generate it from the original code?
    For small project it is obviously easiest to just manually copy the data out of the view in the uVision screen window. For very large project this is clearly not the best way to do it due to being error prone.
    My goals are not particularly dependant on any particular format. I am interested that the dependency information include both file names and path information. My other reality goal is that I want this process to be scriptable (automated) so that if the sources and includes defined in the Keil project change that the tool (script) can be run again to update the export information.
  • I have a script that does that:
    sourceforge.net/.../includes.awk
    It creates a dependency tree in make syntax. It shouldn't be difficult to adopt for whatever kind of format you desire. It's written in awk(1) and calls test(1).
    The output looks like that:
    > scripts/includes.awk src/main.c
    src/hsk_isr/hsk_isr.h: src/hsk_isr/hsk_isr.isr
    src/hsk_flash/hsk_flash.h: src/hsk_isr/hsk_isr.isr
    src/hsk_timers/hsk_timer01.c: src/hsk_timers/hsk_timer01.h
    src/hsk_timers/hsk_timer01.h: src/hsk_timers/hsk_timer01.isr
    src/hsk_icm7228/hsk_icm7228.c: src/hsk_icm7228/hsk_icm7228.h
    src/hsk_pwc/hsk_pwc.c: src/hsk_pwc/hsk_pwc.h src/hsk_isr/hsk_isr.h
    src/hsk_pwm/hsk_pwm.c: src/hsk_pwm/hsk_pwm.h
    src/hsk_adc/hsk_adc.c: src/hsk_adc/hsk_adc.h src/hsk_isr/hsk_isr.h
    src/hsk_can/hsk_can.c: src/hsk_can/hsk_can.h
    src/hsk_pwc/hsk_pwc.h: src/hsk_isr/hsk_isr.isr
    src/hsk_adc/hsk_adc.h: src/hsk_isr/hsk_isr.isr
    src/hsk_wdt/hsk_wdt.c: src/hsk_wdt/hsk_wdt.h src/hsk_isr/hsk_isr.h
    src/hsk_boot/hsk_boot.c: src/hsk_boot/hsk_boot.h src/hsk_isr/hsk_isr.h src/hsk_io/hsk_io.h
    src/main.c: src/config.h src/hsk_boot/hsk_boot.h src/hsk_timers/hsk_timer01.h src/hsk_can/hsk_can.h src/hsk_icm7228/hsk_icm7228.h src/hsk_adc/hsk_adc.h src/hsk_pwm/hsk_pwm.h src/hsk_pwc/hsk_pwc.h src/hsk_flash/hsk_flash.h src/hsk_wdt/hsk_wdt.h src/hsk_io/hsk_io.h
    src/hsk_boot/hsk_boot.h: src/hsk_isr/hsk_isr.isr
    src/hsk_isr/hsk_isr.c: src/hsk_isr/hsk_isr.h
    src/hsk_flash/hsk_flash.c: src/hsk_flash/hsk_flash.h src/hsk_isr/hsk_isr.h
  • How does it handle system include files?
  • You have to pass it the include directory, ending with a / to mark that it's not a file.
    > scripts/includes.awk src/main.c inc/
    src/hsk_timers/hsk_timer01.c: inc/Infineon/XC878.h src/hsk_timers/hsk_timer01.h
