interrupt during reset causes cy7c68013a to hang
I am using the cy7c68013a dev board to test using interrupts. I have based my code on the example given with the dev board. It all works fine as long as there is no signal connected to int0 during reset. If I connect a pulse generator to it that gives a 500us pulse every 10ms then it hangs. Windows reports a fault in device manager.
