Hi All, I am not an expert on ARM yet but an average guy for uC.
I am trying to get hands on with LPC2148 and plan to use it in next project.
One wonderful thing that I came across (I come form a background where we use 8051/mega16 uC) is USB IAP. So without any UART/Serial cable, I can flash program just by using USB cable.
Did some changes like 1. generating bin file (using fromelf --bin ....) and 2. changing IROM1 from 0x0 to 0x2000
to make program work with IAP.
I tasted some program and those worked very well.
But the issue is arising when I try to use Timer0 interrupt. I see controller getting stuck somewhere just after 1st int.
I checked with "Use Memory Layout with Target Dialog" selected and de-selected both. Nothing worked.
This has something to do with vector table but I am not able to make out what?
Any help on this would be appreciated.
Remember, I just made 3 above mentioned changes after creating new project. If there is anything else, please let me know.
LPC2148 may be old. But til now I was using AVR (8-bit) controllers. So I planned to move a level up so that next projects can be better.
And, to get familier with the uC, I got this Development board at very good rate. "">www.nex-robotics.com/.../arm7-lpc2148-development-board.html"
This will ramp up the development time.
I surely have a look at LPC17xx/13xx. But now as I have started with this, I plan to understand it properly. So the jump to 17/13xx would be easier.
BTW, thanks for suggestion.
Exception Vectors -> ARM design Vectored Interrupt Controller -> NXP design One of the Exception Vectors is linked to Vectored Interrupt Controller.
LPC21xx / LPC23xx -> ARM7 -> VIC LPC17xx (LPC13xx?) -> ARM Cortex-M -> NVIC
ARM7 is very different from Cortex-M; and due to the foundry process etc, Cortex-M might be cheaper than ARM7. But of course, different projects have different considerations, LPC2148 might still be the best choice for your projects. (When will NXP terminate LPC21xx?)
