Hi guys,
i have a problem about selection of DMA1 channels. i'm using an example application. and i did some changes on it. Application uses DMA1_Channel3. i have changed channel as DMA1_Channel1. But compiler give this error message:
..\source\main.c(112): error: #20: identifier "DMA1_Channel1" is undefined
if i use DMA1_Channel3, there is no problem. i opened _map.h and i comfirmed that DMA1_Channel1 and DMA1_Channel3 are defined.
my DMA code is here:
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)bellek1; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)bellek2; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 512; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Enable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; DMA_InitStructure.DMA_M2M = DMA_M2M_Enable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); //DMA_ITConfig(DMA1_Channel1, DMA_IT_TC | DMA_IT_HT | DMA_IT_TE, ENABLE); DMA_Cmd(DMA1_Channel1, ENABLE); </pre| please help me. best regards
Maybe it is not defined for your _specific_ ARM chip...?
But, clearly, that definition is not visible to the compiler at line 112 of ..\source\main.c !!
Is that header #included by your ..\source\main.c ?
Is the definition active? (ie, not disabled by some #if...)
thanks for your comments. my chip is STM32f103ZET6. you can see my a bit of map.h here
#ifdef _DMA1_Channel1 #define DMA1_Channel1 ((DMA_Channel_TypeDef *) DMA1_Channel1_BASE) #endif /*_DMA1_Channel1 */ #ifdef _DMA1_Channel2 #define DMA1_Channel2 ((DMA_Channel_TypeDef *) DMA1_Channel2_BASE) #endif /*_DMA1_Channel2 */ #ifdef _DMA1_Channel3 #define DMA1_Channel3 ((DMA_Channel_TypeDef *) DMA1_Channel3_BASE) #endif /*_DMA1_Channel3 */ #ifdef _DMA1_Channel4 #define DMA1_Channel4 ((DMA_Channel_TypeDef *) DMA1_Channel4_BASE) #endif /*_DMA1_Channel4 */ * * *
when i use DMA1_channel3 and close the code part in map.h as you can see below, i receive same error message for DMA1_channel3:
/*#ifdef _DMA1_Channel3 #define DMA1_Channel3 ((DMA_Channel_TypeDef *) DMA1_Channel3_BASE) #endif*/
i think, it shows that i included it there is no problem. i'm using dma for fsmc for LCD driving. i'm confused :(
hello all,
i found the problem. i channged conf.h. some definations was closed. i opened them after then everting is ok:) thanks
