I´m using the INF below for Win 7 64 bit, but it doesn´t work well... When I attach the device, the connections remains unstable and Windows looses the device as If I was removing it. Besides, If I remove the device and attach it again, Device Manager shows it as a com port but with an exclamation point signaling that the Device couldn´t be started (Error Code 10). If I repeat this process removing and reattaching the device after N Trials Windows recognizes it again normally.
Does anyone faced this ? Does this INF really works in Win 7 64 bit environnments ?
; ; Keil - An ARM Company Communication Device Class driver installation file ; (C)2007-2008 Copyright ;
[Version] Signature="$Windows NT$" Class=Ports ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318} Provider=%Keil% ;;; LayoutFile=layout.inf ;; not supported in Vista and later DriverVer =04/14/2008, 5.1.2600.5512 ; CatalogFile=mcb2300-vcom.cat
[Manufacturer] %Keil%=DeviceList,ntamd64
;------------------------------------------------------------------------------ ; Device list ;------------------------------------------------------------------------------
[DeviceList] %DESCRIPTION%=MCB2300USB, USB\VID_c251&PID_1705 %COMPOSITE% =MCB2300USB, USB\VID_FF28&PID_0001&MI_01
[DeviceList.ntamd64] %DESCRIPTION%=MCB2300USB, USB\VID_c251&PID_1705 %COMPOSITE% =MCB2300USB, USB\VID_FF28&PID_0001&MI_01
;------------------------------------------------------------------------------ ; Installation ;------------------------------------------------------------------------------
[SourceDisksNames] ;;; this blank section satisfies chkinf [SourceDisksFiles] ;;; this blank section satisfies chkinf
[DestinationDirs] FakeModemCopyFileSection=12 DefaultDestDir = 12
[MCB2300USB] include=mdmcpq.inf CopyFiles=FakeModemCopyFileSection AddReg=MCB2300USB.AddReg
[MCB2300USB.AddReg] HKR,,DevLoader,,*ntkern HKR,,NTMPDriver,,usbser.sys HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[MCB2300USB.Services] AddService=usbser, 0x00000002, DriverService
[DriverService] DisplayName=%DRIVER.SVC% ServiceType=1 StartType=3 ErrorControl=1 ServiceBinary=%12%\usbser.sys
;------------------------------------------------------------------------------ ; String Definitions ;------------------------------------------------------------------------------
[Strings] Keil = "Keil - An ARM Company" DRIVER.SVC = "MCB2300 USB VCom Driver" DESCRIPTION= "MCB2300 USB VCom Port" COMPOSITE = "MCB2300 MSC-CDC COM Port"
Why do you have such impression that the INF causes your trouble? Sound like it's a problem of your device.
Tsuneo
Because with the same device and same INF above, if I use Win Xp 32 bit for example, everything works fine. Its a specific Win 7 64 bit problem.
Then, it's a problem of your Windows box.
Maybe, you've dragged the INF from this post http://www.keil.com/forum/17039/
After I posted the INF, Keil has gotten MS certification using the INF on the post, with a little modification of strings and device list. No difference on the major sections. Keil distributes certified INF in this folder, now. C:\Keil\ARM\Boards\Keil\MCB2300\USBCDC\ - mcb2300-vcom.inf - mcb2300-vcom_x86.cat - mcb2300-vcom_amd64.cat
Thanks Tsuneo. Did you mean that the certified INF is avaiable for download from Keil web site ? Complementing, my device is used by several clients with Win 7 64 bit, and the problem occurs in all of them...
If you take acloser look, the post contains the installation paths for the INF files which seems to correspond with directories you get when you install the MDK tools on your computer. Have you checked what files you find there when installing the most current version?
Have a look at our inf file svn.openrobotino.org/.../ We are using it with win7 64bit without any problems.
The problem is not the Win 7 Driver.
It´s on a lower layer and relies in some USB ports sensibility or timing problems with computers using Intel 5 Series USB Controllers or newer ones (just Intel)... In the beginning it seemed to be a Win 7 64 bit driver problem, due to the fact that new machines usually are running Win 7 64 bit.
As I´ve seen in several Foruns, this problem occurs with a lot of devices (mouses, smartphones, etc)... I´ve done several test with a lot of different notebooks, and onfirmed this problem. With Intel 5 and 6 Series chipset machines, I´ve had to use a USB hub in order to put the USB link to work perfectly.. With AMD brand new chipset machines it worked very well.
Does anyone has some experience regarding this ?
I am running a STM32F205 and using the FS USB port as a device as a MSD ( memstick) the code is keils USB and FS-FLASH.
If I plug the device into a XP PC it see the device and works okay.
If I plug in a windows 7 desktop directly to the PCs USB ports it fails to enumerate the device and comes up with a device error, but yet when I plug it into a USB hub attached to the PC ( a dell monitor ) it immdeiately sees the USB device as a MSD and functions as expected.
If this is an intel USB chip set issue how can you solve the problem ? Are there settings you can force the USB host to use ?
Has anyone else come across this issue as well
