using mdk 4.72.10.0 device lpc2388
after two years I finally upgraded to the latest keil mdk everything works except for this strange anomaly.
if I change the IPMode (between Dhcp and Static) or change the ftp (between Passive and Active)
the software automatically resets (A reset was previous needed but one had to do it in software)
Does the keil library automatically handle the reset for you (If so were is this documented?)
//**************************************************************************************** if I call updateInternetSectorParameter(FTP_MODE_OFFSET, (unsigned char *) &networkActiveMode, 1); or updateInternetSectorParameter(MY_IP_MODE_OFFSET, (unsigned char *)&networkDHCPMode, 1);
witch in turn (updateInternetSectorParameter ) calls
WriteBlock(INTERNET_SECTOR, (U8*)writeBuf, 1);
once (WriteBlock) is called the system hangs for 5 seconds and then resets
I already increased any time out I could find with no change any Ideas
