debugger pointing to wrong code lines
I need some help figuring out some bizarre behavior with the uVision debug environment. If I set a breakpoint in the following code, the debugger stops at the line labeled --BP-- for any and all values of the variable PWMticks. If I let the code run with no breakpoints, it appears to work correctly. Hardware and software details are listed below. Thanks for any suggestions or help
volatile int PWMdutyCycle = 3;
volatile int PWMticks = 0;
void SysTick_Handler (void)
        PWMticks++;
        if(PWMticks == 3)
--BP--          GPIO_ResetBits(GPIOC, GPIO_Pin_12);
                   //Hit a break point here for all values of PWMticks == 1-9
        else if(PWMticks == 9)
                PWMticks = 0;
                GPIO_SetBits(GPIOC, GPIO_Pin_12);
        else
                PWMdutyCycle = 0;
Hardware
STM3241G-Eval board, ( STM32F417IG ).
ST-Link debugger
Tool chain info
IDE-Version:
µVision V4.70.0.0
Tool Version Numbers:
Toolchain: MDK-ARM Standard Version: 4.70.0.0
Toolchain Path: C:\Keil_ARM\ARM\ARMCC\bin\
C Compiler: Armcc.Exe V5.03.0.24
Assembler: Armasm.Exe V5.03.0.24
Linker/Locator: ArmLink.Exe V5.03.0.24
Librarian: ArmAr.Exe V5.03.0.24
Hex Converter: FromElf.Exe V5.03.0.24
CPU DLL: SARMCM3.DLL V4.70.0.0
Dialog DLL: DCM.DLL V1.9.0.0
Target DLL: STLink\ST-LINKIII-KEIL_SWO.dll
Dialog DLL: TCM.DLL V1.12.0.0
