Hii, i want to write the c code for communication between max5821 i2c dac with 89s8253. i refered the datashet of max5821 and know all the registers inside it. do anyone has interfacing code Thanks with regards
Sorry, but your post doesn't compute.
You say that _you_ want to write code.
Then you ask for someone else to send you the code.
just a warning
it is a known fact that if you can not code it yourself, downloaded code is worthless.
Actully I dont have that much time to implement the whole logic of i2c and dac, obviously i will not copy the code as it is i have to make some changes acc to my requirement. please help me in this. its urgent
i can code it myself erik, but i m not sure about my i2c logic. downloaded would be little bit helpul.
i can code it myself .... i have to make some changes acc to my requirement. please help me in this
if you can code it yourself, then you do not need help adapting the downloaded code.
coding it yourself means coding WORKING code yourself, NOT writing some lines of code
Thanks Erik for your "NO", i have completed it myself :)
