Greetings,
Is it possible to find the C code( not asm) from a hex file written in Atmel 8051 series microcontroller?
My hex data is on dropbox ( 7kb ) :
www.dropbox.com/.../MetroTrainprototype.hex
Also please check the correctness of the code. It needs hardware of :- a 16x2 LCD, a EM-18 RFID reader, L293D I.C.
With Thanks
Uday
No.
The rest is therefore irrelevant.
No: because there is no direct 1:1 mapping from 'C' (or any other high-level language) to machine code - so there is no such thing as the 'C' source.
You could construct a 'C' file which could be compiled back to the same object - but it would not be unique.
"please check the correctness of the code"
This is impossible without a complete definition (aka "specification") of what, exactly, constitutes "correct"...
