using Realview Ulink2 for STM32 with KeiluVision
Pls extend your help to sort out the below issue.
We have to program STM32Miniv3 development board, I tried to connect Realview ULINK2 debugger with the kit.
when i connect the debugger with Keil uVision 4.72a the firmware in ULINK 2 is updated automatically.
In the device manger the system shows(Keil ULINK 2 - CMSIS-DAP) when the USB is plugged in the PC.
when i try to connect the same debugger with older version of keil the debugger is not getting connected with the kit.
Pls help me out to sort the issue. I want to use the debugger with older version keil also.
Looking forward for your reply at the earliest.
with Thanks & Regards
K Jagdish
