Memory allocation
Hello all,
I am new to developing code for ARM based processors under the Keil environment and as such finding my way around the IDE.
Can someone clarify how to accurately establish the following:
a) The size of a built application. I suspect this has something to do with rw-data,ro-data and zi-data but I need clarification on what each is.
b) How much memory that application is using when running (if possible).
Regards
Barry
  • The last few lines in the .map files will show the "Total ROM Size (Code + RO Data + RW Data) and the "Total RW Size (RW Data + ZI Data). However, if you are using dynamic memory allocation (malloc) then this figure includes the Heap space but not how much of it you are using as this dynamically changes at runtime.
