I Know all the values and Location to Set desired CRP(CODE READ PROTECTION)...but doesn't know how can i set this in my program or is there any other way to SET CRP.....
Just specify in the startup file that you have a constant to store at that specific absolute address.
But Actually i don't know how to do it......if you will specify in brief than it will be better for me.....how to do it......
There are a few times when getting the final solution quickly is the best alternative.
But it is often better to _not_ get the solution directly but instead having to spend some own time looking for it. Why? Because of all the additional things people tend to learn while googling for something.
The only way we can keep up with constantly progressing technologies is by keeping our eyes open for new things to learn.
It really shouldn't take long time to manage to find some information about how to specify an absolute code area in the startup file, and how to there declare a 4-byte constant with one of the CPR values specified in the processor user manual.
So one instruction line for the assembler to tell the address and that the constant should be read-only in a code segment. And one line to tell that it is a 32-bit value and what value it is.
Got it the solutions...thank you.....
just few lines and got best result
;// <h> Code Read Protection level (CRP) ;// <o> CRP_Level: ;// <0xFFFFFFFF=> Disabled ;// <0x12345678=> CRP1 ;// <0x87654321=> CRP2 ;// <0x43218765=> CRP3 (Are you sure?) ;// </h> CRP_Level EQU 0x12345678 IF :LNOT::DEF:NO_CRP AREA |.ARM.__at_0x01FC|, CODE, READONLY CRP_Key DCD CRP_Level ENDIF AREA |.text|, CODE, READONLY
Nice that you got it working.
The good thing with the above is that you now left one more hint for others to pick up with Google (if they decide to try Google).
