Hi I am using lpc4357 based on MCB4300. Ethernet maximum speed is too low. here is a part of FTP code which is using USB MSD as a data storage:
U16 tcp_callback (U8 soc, U8 evt, U8 *ptr, U16 par) { par = par; if (soc != socket_tcp) { return (0); } switch (evt) { case TCP_EVT_DATA: break; case TCP_EVT_CONREQ: return (1); case TCP_EVT_CONNECT: printf("connect\r\n"); return (1); } return (0); } ... SystemCoreClockUpdate(); SysTick->LOAD = (SystemCoreClock/ 100) - 1; SysTick->CTRL = 0x05; init_TcpNet (); socket_tcp = tcp_get_socket (TCP_TYPE_SERVER, 0, 1000, tcp_callback); if (socket_tcp != 0) { tcp_listen (socket_tcp, 1001); } while (1) { usbh_engine_all(); con = ((usbh_msc_status(1, 0) << 1) | usbh_msc_status(0, 0)) & 3; if (con ^ con_ex) { /* if connection changed */ if ((con ^ con_ex) & ~con & 1) /* if device 0 not connected */ printf ("\nDisconnected Drive U0:"); if ((con ^ con_ex) & con & 1) con |= init_msd ("U0:"); if ((con ^ con_ex) & con & 1) /* if device 0 connected */ printf ("\nConnected Drive U0:"); if (con) printf ("\nCmd> "); /* display prompt */ else printf ("\nNo drives connected, please connect any drive ... "); fflush (stdout); con_ex = con; } main_TcpNet (); timer_poll (); }
CPU is working at 204MHz. USB clock is 480MHz. in CGU all peripherals are connected to PLL1 and it is working at 204MHz.
download speed is about 4MB/s (in FlashFS sample code I could achieve 9MB/s for read and about 8MB/s for write)
I've manipulate FTP_UFI.c just for finding the maximum speed on ftp in this way:
unsigned long size=0; U16 ftp_fread (void *file, U8 *buf, U16 len) { /* Read 'len' bytes from file to buffer 'buf'. The file will be closed, */ /* when the number of bytes read is less than 'len'. */ size+=len; if (size>100000000) return 0; else return len; }
I know it is not working properly but I've omitted time of fread for speed test. in download progress speed is about 5.5MB/s. I think it is a disaster.
I've set it as a TCP server and through put is about 2% of 100Mb/s
this code is the same as my LPC1788 board and download speed on LPC1788 with SD card is about 2MB/s(it is usual) and as a TCP server is about 80% of 100Mb/s(is it so perfect)
I've changed SysTick setting but this is the most through put that I could obtain.
some critical definitions in net_config.c:
#define MEM_SIZE 2048 #define TICK_INTERVAL 10
Do you have any idea?
You seem to talk about 5.5 megabyte/second and then about 2% of 100 megabit/second, i.e. 2 megabit/s.
5.5 megabyte/s is way more than 2 megabit/s.
Maybe I'm just misunderstanding what you are saying.
Later 2 MBps is 80% of 100 Mbps
The numbers and percentages are all over the place. Please restate with some clarity and consistency.
If you were getting 5.5 MBps, it would be at least half the bandwidth of a 100 Mbps channel. Make sure of distinctions about what are bytes and bits.
