Hi all.
NAND MT29F1G08ABBDAH4 + Cortex m4 at Keenetis K70f15 dont' works.
I've began to use mdk473 instead of mdk503 after conversation with Keil support team. Purpose is still the same - to mount File System on NAND flash and to read/to write some files.
What did I do, step-by-step:
1. An empty project was created.
2. Some files were added: startup_MK70F15.s, system_MK70F15.c, main.c nand_mk70.c, nand_mk70.h, file_config.c FS_CM3.lib
3. startup_MK70F15.s was configured: HeapSize was set to 0x1300 (up to 8 files), StackSize was set to 0x400.
4. File_config.c was configured: PageSize was set to 2112 and DefaultDrive flag was set, Nand0 flag was enabled
5. The project was compiled = OK
All the functions(Init, UnInit, Erase, PageRead and PageWrite) are exists in nand_mk70.c, defined and compiled.
Here is all the code, which I'm trying to run.
#include <rtl.h> #include <stdio.h> int main(){ if (finit (NULL) != 0) { printf ("Initialization failed.\n"); printf ("The drive is not enabled in the file 'File_Config.h'\n"); } while(1); return 0; }
But program doesn't starts and goes to infinite loop before main(), at _sys_open, asm:
_sys_open: 0x00001010 B50E PUSH {r1-r3,lr} 0x00001012 E9CD0100 STRD r0,r1,[sp,#0] 0x00001016 F7FFFE75 BL.W strlen (0x00000D04) 0x0000101A 9002 STR r0,[sp,#0x08] 0x0000101C 4669 MOV r1,sp 0x0000101E 2001 MOVS r0,#0x01 0x00001020 BEAB BKPT 0xAB 0x00001022 BD0E POP {r1-r3,pc}
at highlighted line.
When I comment "finit()" everything is OK, any another code works fine. What the problem could be there? It seems I've missed something very important, but what exactly?
Do you have some putchar/printf code some place else (SystemInit for CMSIS)? Have you implemented any sort of semi-hosting for the serial output of your board. The BKPT suggests it's trying to call OS hosting functions you're not supplying.
No, I have no putchar/printf code somewhere else.
The project is modified example from ..\ARM\Boards\Freescale\TWR-K70F120M\RL\FlashFS\NAND_File\
There were some printf/putchar code, but i cut it out and removed all the implementation from retarget.c. Serial.h and getline.c are also removed. All the code uses string constants instead of IO functions.
Can you advice me a cup of docs about BKPT, etc.?
