When I try to build my project, I encounter the error Switches.uvgui.Administrator(1): error: A1163E: Unknown opcode version="1.0" , expecting opcode or Macro
amongst many others.
The guilty line is <?xml version="1.0" encoding="UTF-8" standalone="no" ?> which is identical to all equivalent files in other projects. What makes this more confusing is that according to the database of errors and likely solutions, this is caused by assembly code, which this file is clearly not.
Does anyone have any ideas why an uvgui.username file would give such syntax errors? I've never altered it.
Ready to provide any other information you may need to help, thanks, Jonathan
This File only stores User related layout information for the IDE. I Do Not really understand why This Is involved in the build process. Did you add it to the project?
