Hello, I am working on a project based on STM32F103VC microcontroller. I tried to find any resource/discussion/application note on clearing of internal SRAM after reset (i.e. initialization of SRAM). Although the topic seems trivial, it is strange that I was unable to find any resource nor example. I tried to investigate startup_stm32f10x_x.s files to find relevant routine without success. Could you please provide information/examples/advices how to clear internal SRAM after reset, what is the best way. If it has to be done in the startup file - plese, suggest an example. Could we use memset function called in the initialisation function before main and how to implement it in a problem-free manner (and any examples?)? Thanks in advance
The C/C++ runtime environment normally clears all RAM as long as the RAM is part of the project. If you have RAM regions not specified to belong to the project, then you need to clear them yourself. If you have RAM regions that requires the hardware to be properly initialized to be able to access the RAM, then your startup code must make sure to make those RAM regions accessible - so setting up DRAM controllers, powering on peripherials with own RAM regions etc.
startup_stm32f1xx.s
; ... ; Reset handler Reset_Handler PROC EXPORT Reset_Handler IMPORT SystemInit IMPORT __main LDR R0, =0x20000000 LDR R1, =0x2000C000 ; 48KB LDR R2, =0xE5E5E5E5 ; Fill Pattern RAM_Init_Loop STR R2, [R0], #4 ; *R0++ = R2 CMP R0, R1 BNE RAM_Init_Loop ; The __main routine resets the stack pointer, and then initialize the static area ; it then CLEARS all the space between there and the stack. LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Reset_Handler ;...
