LPC2148 code is not executing
I have an epic problem with LPC2148. I am able to write a code in its flash memory however core is not executing a code. I tried following LED blinking code. Also I checked for crystal, its working fine (observed 12MHz waveform on oscilloscope).
#include <lpc21xx.h>
//void delay(void);
int main(void)
{ IO0DIR = 0xFFFFFFFF; // Configure all pins on Port 0 as Output IO0SET = 0xFFFFFFFF; // Turn on LEDs
while(1) {
} return 0;
/*void delay(void)
{ int z; for(z=0; z<4000; z++);
