Error using UART1 as a FIQ
I have a firmware runing fine with UART1 as a normal IRQ.
Recently I realize that I should use UART1 as a FIQ to be sure that the communication works fine.
As an IRQ I had the this defintions:
VICVectAddr7=(unsigned long) ISR_UART1;
VICVectPriority7=0x00000008;
VICIntSelect &= 0xFFFFFF7F;
VICIntEnable |= 0x00000080;
void ISR_UART1 (void) __attribute__ ((interrupt("IRQ")));
void ISR_UART1
{ .... .... cTmp=U1IIR; VICVectAddr = 0x00000000;
As a FIQ I changed to:
VICIntSelect |= 0x00000080;
void FIQ_Handler(void) (void) __attribute__ ((interrupt("FIQ")));
{ DEBUG = 1
DEBUG = 0
DEBUG = 1 ISR_UART1(); //it is the only one FIQ so I call imediatly this funciton
DEBUG = 0
With the osciloscope I can see the the Debug going '1'->'0'->'1' but it never leaves the function and don't get the final '0'.
Can anyone help me with this???
  • Do you really think a FIQ handler should call an IRQ handler?
    Shouldn't you just throw away your new FIQ handler and instead adjust the UART code to be a FIQ handler? After all, you don't want to waste time with an extra function call.
  • Problem resolved.
    The problem is that I leave the code:
    And when I call the function ISR_UART1 the program don't leave this function.
    I think that the problem is because of this: 1- When start FIQ_Handler the CPU saves the LR making a PUSH. 2- Then I was calling the ISQ_UART1 (with the statement: void ISR_UART1 (void) __attribute__ ((interrupt("IRQ"))); ) So the LR was saved with a PUSH to the stack 3- When the ISR_UART1 ends it makes as operation like RETI (return from an Interrupt). with this the CPU will load the LR previous to the call of the ISR_UART1.
    I think the problem was something like this.
    Thanks,
    Carlos Costa
  • Yes - as I indicated in my first post, a FIQ handler isn't supposed to run any code that thinks it is an IRQ handler. That will seriously break the intended use of the stacks for FIQ and IRQ processing.
