What is the proper syntax to place struct functions in specific regions? Using something like the example below appears to ignore the #pragma statement, e.g. the object code for foo::bar() is not placed in section "sram2". Using #pragma section on a block would be preferable to __at() on every function as some structs define a large number of functions. MDK version is 4.71 and target is an ARM Cortex-M4. Thanks.
#pragma arm section code = "sram2" struct foo { int bar(int x) { int ret; // Some logic return ret; } } #pragma arm section code
Forgot to use the pre tags in the example. It should look as follows:
