I have the following variables:
#define X ... ... code unsigned char pin[X] = { ... }; // there are values here, no 0xFF ... struct { unsigned char pin[X]; } info;
and I need to copy the values from pin into info.pin. However, even direct assignment doesn't change the info.pin values. i.e.:
info.pin[0] = pin[0]; info.pin[1] = pin[1]; info.pin[2] = pin[2]; ... info.pin[X - 1] = pin[X - 1];
the watch window shows info.pin values are still 0xFF and indeed when another code that needs info.pin checks (after the assignment above of course), the values are still 0xFF. What do I have to do to make the values copied?
Sorry, the pin declaration should be:
unsigned char code pin[X] = { ... }; // there are values here, no 0xFF
Are you sure you can edit a 'code' variable??
He is reading the contents of 'code' variable and writing it to 'ram' variable.
You need to look at some disassembly for the piece of code to see what the compiler is making.
Same variable names (sigh!!).
The other way around is to use pointers.
> You need to look at some disassembly for the piece of code to see what the compiler is making. Here are the first 4 assigments (since it's generally the same):
653: Sys_ebpUPINs[0] = cbaUPINs[0]; C:0xAA4E 9003B3 MOV DPTR,#cbaUPINs(0x03B3) C:0xAA51 E4 CLR A C:0xAA52 93 MOVC A,@A+DPTR C:0xAA53 900D02 MOV DPTR,#0x0D02 C:0xAA56 F0 MOVX @DPTR,A 654: Sys_ebpUPINs[1] = cbaUPINs[1]; C:0xAA57 9003B4 MOV DPTR,#0x03B4 C:0xAA5A E4 CLR A C:0xAA5B 93 MOVC A,@A+DPTR C:0xAA5C 900D03 MOV DPTR,#0x0D03 C:0xAA5F F0 MOVX @DPTR,A 655: Sys_ebpUPINs[2] = cbaUPINs[2]; C:0xAA60 9003B5 MOV DPTR,#0x03B5 C:0xAA63 E4 CLR A C:0xAA64 93 MOVC A,@A+DPTR C:0xAA65 900D04 MOV DPTR,#0x0D04 C:0xAA68 F0 MOVX @DPTR,A 656: Sys_ebpUPINs[3] = cbaUPINs[3]; C:0xAA69 9003B6 MOV DPTR,#0x03B6 C:0xAA6C E4 CLR A C:0xAA6D 93 MOVC A,@A+DPTR C:0xAA6E 900D05 MOV DPTR,#0x0D05 C:0xAA71 F0 MOVX @DPTR,A
> The other way around is to use pointers. No, that doesn't work either. When I said "even direct assignment..." that means I've tried every high level possibility. First I use a copy function, then pointer + loop, copy to local array first (this time the value gets copied, but still fails when copying values from local array to the array in the struct), finally I use direct assignment.
The assembly code looks fine.
Do the locations 0x0D02 - 0x0D05... physically exist? Is the external RAM, on-chip XRAM or have you connected off-chip external RAM?
Found the problem, the address is actually a flash address instead of RAM, that's why simple copy by assigment doesn't work. Problem solved.
