Newbie trying to make multiple interrupts work! I have been playing with the STM32-Discovery board and I am trying to make multiple interrupt handlers work at the same time. I am able to execute one interrupt, but I can’t get others to work.
The first interrupt handler is based on the blue button (PA0) (Code: see ButtonInit() in www.embedds.com/.../ ); it works great!
I want an other interrupt line and so I have picked PA4 and I have made the following changes:
void newInterrupt() { //EXTI structure to init EXT EXTI_InitTypeDef EXTI_InitStructure; //NVIC structure to set up NVIC controller NVIC_InitTypeDef NVIC_InitStructure; //Connect EXTI Line to Button Pin GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource4); // <------ CHANGE 1 //Configure Button EXTI line EXTI_InitStructure.EXTI_Line = EXTI_Line4; // <------ CHANGE 2 //select interrupt mode EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //generate interrupt on rising edge EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; //enable EXTI line EXTI_InitStructure.EXTI_LineCmd = ENABLE; //send values to registers EXTI_Init(&EXTI_InitStructure); //configure NVIC //select NVIC channel to configure NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn; //<------- CHANGE 3 //set priority to lowest NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F; //set subpriority to lowest NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F; //enable IRQ channel NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //update NVIC registers NVIC_Init(&NVIC_InitStructure); }
I made 3 changes (see above) and I can’t get it to work. If I understand the interrupt mechanism correctly, PA4 maps to EXTI4; whose signal is mapped onto the “EXTI1_IRQn” line because EXTI4 resides on AFIO_EXTOCR2 (EXTI0 resides on AFIO_EXTOCR1 and so its EXTI0_IRQn... the example sticks to this and it works). Is my understanding correct? Whats wrong with the above code and how can I make it work. Any suggestions are highly appreciated.
Thanks, Pradeep
