Hi there, I have a ulink2 and a ATSAM3S2A with 128kb Flash. The connection via JTAG/SW seems to be okay, I see the device name and the IDCode in the Debug window. When I start to download the code into the flash I get "Full Chip Erase Failed!" and "Cannot access Memory". I have already checked the adress range (0x00400000, Size 0x00020000) and the RAM for algorithm (0x20000000, Size 0x0800). Also I reduced the Max Clock (JTAG-Adapter), down to 100KHz and I've tried to download the code without a erase or checked "Download to Flash" in "Download options". Nothing solves the problem.
Has anyone an idea?
Thank you very much in advance for your efforts!
Hi, I am also facing same problem.In our PCB AT91SAM3U4E MCU and nand flash are major IC. 1. PCB with AT91SAM3U4E MCU is working fine. 2. PCB with AT91SAM3U4E MCU and NAND flash is giving same problem as you mentioned. If you solved problem please help me.
Hi all. I have the same problem. My device is AT91SAM3U4E and I want to program internal flash. But I get the "flash download failed cortex-m3" and "cannot access memory" error message. Can anybody help me? thanks in adavnce.
