LPC1788 Executing from SDRAM
I'm using LPC1788 in my project and I need to execute some code from SDRAM at address 0xA0000000, but there is one issue. The issue is that MPU considers this address a non executable memory space.
What I need is to how to set MPU registers to make the SDRAM as a executable memory space.
I could not understand how to do this by user manual, it is very confusing because the information is not clear enough.
Does anyone knows how to setting it?
Thankyou!
Henrique
  • The issue is that MPU considers this address a non executable memory space
    I am working with a MPU enabled FreeRTOS. I still did not try what you describe, but I also did not find any such limitation in the user manual. Can you indicate where you found it?
  • This is the code I use to program a specific MPU region:
    static void mpu_region_setup(uint32_t a_addr,
                                 uint32_t a_region,
                                 uint32_t a_size,
                                 uint32_t a_ap,
                                 uint32_t a_mem_attrib,
                                 uint32_t a_srd,
                                 uint32_t a_XN,
                                 uint32_t a_enable)
        // Setup procedure for each region
        MPU->RBAR = (a_addr & 0xFFFFFFE0) | (a_region & 0xF) | 0x10 ;
        MPU->RASR = ((a_XN & 0x1)<<28) | ((a_ap & 0x7)<<24) | ((a_mem_attrib & 0x3F)<<16) | ((a_srd&0xFF)<<8) | ((a_size & 0x1F)<<1)| (a_enable & 0x1) ;
  • Usage:
    // memory pool size must be a power of 2
    // memory pool address must be a multiple of the size
    void user_tasks_enable_ddc_access(void)
        portBASE_TYPE xRunningPrivileged = portRaisePrivilege() ;
        // MPU->CTRL = 0 ; // Disable MPU first
        mpu_region_setup( (uint32_t)&umm_heap,
                           7, // always reprogramming MPU region 7
                           e_mpu_region_size_4_mega_byte,
                           3, // full access
                           0, // strongly ordered, shareable
                           0, // subregion disabled
                           0, // don't allow instruction execution
                           1) ; // region enabled
        // MPU->CTRL = 1 ; // Enable MPU
        portRESET_PRIVILEGE( xRunningPrivileged ) ;
