Hi All! Any good example for software UART (SW) and retranslate data between SW and hardware (HW) UART on C51 using C - Keil Compiler? Using EXT0 Interrupt as receiver datect for "SW" Uart ?
Pardon??
www.lmgtfy.com
Who cares about good examples of sw UART, when there exists chips with multiple hw UART?
You need a low baudrate if you want anything else to happen while that sw UART is busy sampling the data line.
I've this Software but have a problem with INT0 interrupt or "getc()" function when I send data to SW-UART.
code:
//Second SW-ASYNC.UART USING INT0 as detect RX data(start bir) #include <stdio.h> //#include <AT89C51RC2.H> #include <at89c51xD2.h> //AT89c51ED2 #include "softuart.h" #define buff_size 16 unsigned char t; bit flag_sw_isr; unsigned char xdata test_buff[8]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37}; //////////////////////////////////////////////////////////////////////////////////////// unsigned char xdata rx_sw_buffer[buff_size]; unsigned char index_sw = 0; /*External ISR Rutine*/ void ext_int0_isr (void) interrupt 0 { flag_sw_isr=0; rx_sw_buffer[index_sw]= getc(); if(++index_sw==buff_size) { index_sw=0; } flag_sw_isr=1; } /*Delay n-ms time.----------------------------------*/ void delay_ms(unsigned char ms) { unsigned int x,y; for(x=0;x<ms;x++) for(y=0;y<1275;y++); } void main(void){ delay_ms(50); index_sw=0; /*EXT_0 ISR Config bits --------------------------------------------------------*/ IT0 = 1; // Configure interrupt 0 for falling edge on /INT0 (P3.2) EX0 = 1; // Enable EX0 Interrupt EA = 1; // Enable Global Interrupt Flag /*------------------------------------------------------------------------------*/ SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* TH1: reload value for 9600 baud @ 11.0592MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; printf("1-HW UART;2-SW UART DEMO\n\r"); printf("test_2 UART_0\n\r"); for(t=0;t<8;t++) //for testing SW putc() func. { putc(test_buff[t]); } flag_sw_isr=1; while(1) { unsigned char i; delay_ms(100); if(flag_sw_isr) { for(i=0;i<16;i++) { putchar(rx_sw_buffer[i]); } } } } //==============================softuart.h==================================== #ifndef __SOFTUART #define __SOFTUART void putc(unsigned char); unsigned char getc(void); #endif //========================softuart.asm========================================= ?SU?PUTC SEGMENT CODE ?SU?GETC SEGMENT CODE PUBLIC _putc PUBLIC getc txd_pin EQU P3.4 ;Transmit on this pin rxd_pin EQU P3.2 ;Receive on this pin ;Formula to calculate the bit time delay constant ;This constant is calculated as: (((crystal/baud)/12) - 5) / 2 ;crystal is the frequency of crystal in Hz ;baud is required baudrate ;Please try to keep baudrate below 9600 ;to get best results :) BITTIM EQU 45; (((11059200/9600)/12) - 5) / 2 ;-------------------------------------------- ;To send data serially ;For C programs ;Protype definition: ; void putc(unsigned char); ;Usage: ; putc(data); ;Return: ; This function returns nothing ; ;For Assembly Programs: ; ;Usage: ; data to be send has to be moved to R7 ; for example: ; mov R7,#'a' ; lcall _putc ;-------------------------------------------- RSEG ?SU?PUTC _putc: push ACC Push PSW mov a,r7 CLR txd_pin ;Drop line for start bit MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For START bit MOV R1,#8 ;Send 8 bits putc1: RRC A ;Move next bit into carry MOV txd_pin,C ;Write next bit MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For DATA bit DJNZ R1,putc1 ;write 8 bits SETB txd_pin ;Set line high RRC A ;Restore ACC contents MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For STOP bit POP PSW pop ACC RET ;-------------------------------------------- ;To receive data Serially ;If you want to use this routine in your ;C program then define function prototype ; as: ; unsigned char getc(void); ; ; Usage: ; data = getc(); ; Return value: ; Returns data received ; ; ;If you are using it in assembly program ; Usage: ; lcall getc ; Return: ; data received is stored in R7 ;-------------------------------------------- RSEG ?SU?GETC getc: Push ACC Push PSW JB rxd_pin,$ ;Wait for start bit MOV R0,#BITTIM/2 ;Wait 1/2 bit-time DJNZ R0,$ ;To sample in middle JB rxd_pin,getc ;Insure valid MOV R1,#8 ;Read 8 bits getc1: MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For DATA bit MOV C,rxd_pin ;Read bit RRC A ;Shift it into ACC DJNZ R1,getc1 ;read 8 bits mov r7,a POP PSW pop ACC RET ;go home END
I've some hardware which I want to use it.
And what problem, exactly, do you have?
When I send data to SW UART (P3.2)INT0 at89c51ed2 "Block" and do nothing until I make RESET or Power OFF -> ON!
Agree with Per, HW solutions should be used. However, if possible. If it is just for fun and not a commercial product, why not? But I do not like those endless discussions on forums, there will be always different opinions, so you may send an personal email to embedded-world at home dot se. For some questions I do have. If it helps, o.k., if not, also o.k. Best regards.
I've some hardware which I want to use it I have a shoe and want to pound a nail into my wall.
If it is just for fun and not a commercial product, why not? because the "learning value" is a big fat ZERO
But I do not like those endless discussions on forums, there will be always different opinions well, if there were not "different opinions" why have a "discussion forum"
Some read the forum title and assume it reads "solution providing place". Where a 'discussion' most likely will provide help, providiong nicely boxed shrink wrapped solutions is not the purpose.
Not at all!
Implementing a UART in software requires understanding a lot of things which will be of general use - not least, how a UART actually works!
Any Idea..???
